Update network lines with new points
  • Nov 22, 2019 9:41 AM UTC
  • 58 views
@takashi
Hello!
I'm having difficulty to update a network lines with new survey points. I want to shift each vertex point of a line (in red) with unique nearest point (black). Can someone help me please?
Thank you.
fmelizard
Forum|alt.badge.img+22
  • Nov 22, 2019 5:47 PM UTC
Hi @sati27 An AnchoredSnapper will snap the line segments to the points but it looks like you might want to iterate through that a few times, gradually increasing the snapping distance until every point has been snapped to. If you want to actually move vertices instead of inserting new ones, then break the lines into segments with a Chopper and use End Point Snapping with the AnchoredSnapper. Also, see https://knowledge.safe.com/questions/94494/finding-the-closest-lines-close-to-gps-points.html
