Update inline annotation with tags
  • Oct 11, 2018 1:39 PM UTC
  • 45 views
geobiker
Forum|alt.badge.img+4
i am changing the text value of ESRI annotations in a GEODATBASE (edit session) by updating the attribute geodb_string_text. This works fine for referenced annoation without overrides.
If I want to update inline annotation with format tags in textstring I can't change the value in geodb_text_string. As result nothing happens. Is this possible with FME and which attributes I have to consider?
Version: FME 2016.1
Thanks
Stefan
trentatsafe
Forum|alt.badge.img+7
Hello @geobiker
Are you able to try writing to geodb_text_string_with_format_tags, as opposed to writing to geodb_text_string?
I believe the former takes precedence over the other text strings, as such any changes should be reflected there with Tag formatting. I hope that helps.
