Update a table using InlineQuerier
  • December 3, 2015
  • 85 views
In FME2015 I want to use InlineQuerier with an UPDATE SQL statement to update data within my workflow. I'm pretty sure the syntax is correct and when I run the workflow there is no error, but nothing comes out of the output port that I generated.
However when I run a SELECT query on the same data with the InlineQuerier, this does output the desired results out of anoutput port.
Are you actually able to use UPDATE statements within InlineQuerier?
  • December 3, 2015
An UPDATE statement does not return any data, that is probably why.
Also, I suspect the InlineQuerier wasn't meant for this scenario at all, so I'm not sure if it's even possible.
David
erik_jan
Forum|alt.badge.img+26
  • December 3, 2015
You can use the SQLExecutor to do inline Update statements.
Or use the DatabaseUpdator transformer to do a Update at the end of the transformation.
fmelizard
Forum|alt.badge.img+22
  • December 4, 2015
David
I suspect you could do an UPDATE statement and then on a subsequent output port a Select and you'd get the updated data out that subsequent port.
  • December 4, 2015
I've tested that before from my curiosity, but the UPDATE statement didn't affect the resulting table from the subsequent SELECT.
