unwanted connecting lines after using network topology calculator
soly
Forum|alt.badge.img+3
Hello ,
i have used network topology calculator then aggregator (group by network id ) .
i have found that there are some unwanted connecting lines that has same network id .
I want to check the reason ?
i am wondering if there is a method to find the connecting points that occur to provide each line the same network id as before ?so I  can check them quickly .
i am looking for a quick method to find unwanted lines that has the same network id .thanks for help
Fme 2021
DanAtSafe
Forum|alt.badge.img+19
  • March 27, 2024
Hi @soly How do you know which lines are unwanted?  Can you attach a screenshot of the problem?
thanks
soly
  • March 27, 2024
@DanAtSafe
i know there are many lines that unwanted Bcs the count of the connecting number is more than expected .
the problem not of the transformer ,the problem of my data  that I have lines are connected and I have to make them unconnect lines by creating gap between them .
my question :
i need to know the points that between each connecting line for same network id ,to check them quickly .
DanAtSafe
  • March 27, 2024
@soly Use a TopologyBuilder and create lists on the nodes and edges, followed by a ListElementCounter to get the number of connections.
