Unique Value generator
  • March 1, 2016
  • 5 replies
  • 83 views
I'm trying to duplicate the Asteryx's Unique Tool (http://help.alteryx.com/9.5/index.htm#cshid=Unique... in FME. Using the DuplicateRemover doesn't give me the results that I want.
This is what I need. I have a field that needs to be unique (FiledB) and it's associated with another field (FieldA). A1A 2A3A4B1B3B4B5C5C6
What I should be getting for result is: A1, B5 and C6.
The result that I get with the RemoveDuplicate by selecting only the FieldB as the unique, or both fileds, doesn't give me this.
Any suggestions?
Best answer by erik_jan
If you use the DuplicateRemover on Field B, followed by a second DuplicateRemover on Field A attached to the Unique port of the first DuplicateRemover you would get the required result.
erik_jan
Forum|alt.badge.img+26
  • March 1, 2016
mark2atsafe
Forum|alt.badge.img+59
  • March 1, 2016
But wouldn't you lose records like that? ie the first pass would leave you A1, B1, C5 and the second pass would leave you just A1, C5 (B is lost)
mark2atsafe
  • March 1, 2016
Why B5, C6? Any reason you can't have B3, C5? Also, if the next record is D1, would that mean you couldn't have A1? That would make a difference, and some scenarios would be im
erik_jan
  • March 1, 2016
After the first DuplicateRemover you have A1, A2, A3, A4, B5, C6 After the second A1, B5 and C6.
mark2atsafe
  • March 1, 2016
Got it. I was looking at the other field first!
