unable to zip shape files in FME server
  • Aug 22, 2019 3:17 PM UTC
  • 7 replies
  • 124 views
Hello!
How can I zip shape files separately in FME server? In my FME I use FeatureWriter to do this and it works great. But when I publish my workspace to FME server it does not work anymore. I have 2 separate shape file types (points and polylines) and I want them to be zipped separately (for example point.zip and line.zip). Afterwards I want to download these zip files from FME server.
Best answer by hollyatsafe
Hi @katrin10,
I am pleased to share that an improvement has been added to FME to allow for nested zipping by the engine and this has fixed the issue with using the Data Download Service to write out zipped datasets.
This fix went into the 2020 beta b20146 which is now available to download from safe.com/beta
philippeb
Forum|alt.badge.img+23
  • Aug 22, 2019 3:54 PM UTC
What does your logs say? Do you use UNC path?
  • Sep 2, 2019 11:40 AM UTC
I don't use UNC path. Log is as follows:
itay
Forum|alt.badge.img+19
  • Sep 2, 2019 12:10 PM UTC
Hi @katrin10,
Maybe this post of @mark2atsafe might help you..https://twitter.com/FMEEvangelist/status/1151524285602762754
  • Sep 23, 2019 8:34 AM UTC
Hi @katrin10,
Unfortunatelly, It does not work with FME server.
  • Sep 23, 2019 8:35 AM UTC
I got an answer from FME, that this is known bug and will be fixed in the future
itay
  • Sep 23, 2019 9:20 AM UTC
Good to know! thanks for sharing.
  • Dec 30, 2019 7:32 PM UTC
Hi @katrin10,
