Unable to update values in ArcSDE Geodatabase
  • June 13, 2024
  • 172 views
spalkar
Hi All,
I am updating few values in ArcSDE Geodatabase (in flat table) using FME workbench but its giving an below error
error : Error while retrieving an ArcObjects update cursor for the table/feature class 'gis.xxx'. The error number from ArcObjects is: '-2147220652'. The error message from ArcObjects is: {}
  • Stack  : FME workbench 2021.1 , ArcSDE Geodatabase, Flat table ,MS Sql Server
  • Workbench screenshot :
  • Error message :
  • Feature writer properties
  • Till now tried below :
    • Using SQL query its possible to update values in SQL management studio with sde use
    • SDE user has privilege to insert/modify/delete
    • Workbench has proper permissions to run it
    • Using ArcPro Standard licenses
    • If we truncate then its truncate the table
    • Since we are using flat table still use geometry remover to remove additional geometry
    • Flat table has valid primary key
Any help/inputs/suggestions would be great !!!
thanks in advance !!
Best answer by hkingsbury
Can you update/add rows to that table via ArcGIS?
If its just a flat table and doesn’t have versioning or archiving on it, it will be much faster to write directly to SQL rather than via SDE
hkingsbury
Forum|alt.badge.img+67
  • June 13, 2024
