Unable to Reproject ESRI ArcGIS Server Feature Service while pushing into SQL Spatial Database
  • Aug 1, 2023 6:04 AM UTC
  • 136 views
joshuajames1979
Forum|alt.badge.img+7
Hi there, I am connecting to Vicmap as a Service (VAAS), which is an ESRI ArcGIS Service Feature Service, which will allow me to bring in the state property data and push it straight into our SQL Database. This will replace a weekly download of MapInfo files which are pushed into SQL via automated procedures.
The ESRI data is in Vicgrid GDA2020 (EPSG:7899) and I am trying to push it out to SQL as UTM55S GDA2020 (EPSG:7855). It doesn't matter which projection tool or coordinate system tool I use the data still outputs as Lat Long with an SRID of 7844. Is there a way I can do this? I thought perhaps I need to output to a different file format and then reproject that file and push into SQL, but I'd rather avoid an extra step if possible.
Regards,
Josh
itsmatt
Forum|alt.badge.img+48
  • Aug 1, 2023 1:20 PM UTC
I'm not familiar with SQL Server but could it be the table you're trying to write to is reprojecting the data as it's coming in? As in SQL Server itself is doing the reprojection to match the SRID defined for the table? what happens if you try and create a 100% new table.
The other thing (probably more likely) is that maybe the geometry column is define as Geography as opposed to Geometry.
https://learn.microsoft.com/en-us/sql/relational-databases/spatial/spatial-data-sql-server?view=sql-server-ver16
joshuajames1979
Thanks for your reply. I do have it set to Geometry type and it is dropping and recreating the table each time. Maybe there is a different transformer required here.
itsmatt
  • Aug 3, 2023 8:17 AM UTC
Well you should be able to check the Setting on the writer and specify the correct coordinate system you want. You should also be able to inspect the data directly before the SQLServer writer and check the coordinate System of the features. The coordinate System Information is in the Feature Information window.
If The writer is set to the coordinate system you want and the data going in are in the coordinate system you want then the issue is most likely happening during export to SQLServer - there could be some warnigns or info in the log file which may be helpful here
joshuajames1979
It looks like I have it working now. I used the PROJProjector transformer, with Automatic Transformation, 7899 as my source coordinate system and 7855 as my destination coordinate system., and 7855 as the Output Coordinate System Tag. In the writer it is set to Drop and Create for table handling, and spatial type is Geometry. I've also changed the spatial column field name. It must have been something in this combination that got it working, or perhaps there was one thing I clearly missed before.
Thanks again.
Josh
