unable to represent a colorful raster read from sde-raster-dataset
  • Aug 5, 2022 8:21 AM UTC
  • 21 views
I'm trying to read a Orthophoto from ArcGis-DB using Reader-Transformer Geodatabase-sde-Raster-Dataset and clip an specific area of the raster using definition of Search Develop. At the End, make a tif export from that.
The Problem is that FME represent the reading raster als grayscale, although the raster has four bands.
How should I export a rgb tif from raster dataset?
I would appreciate any Help in advance.
with regards
Soschianet
nampreetatsafe
Forum|alt.badge.img+14
Hi @soschianet​: When you inspect the raster from the Geodatabase Reader feature type, does it show up in FME in color or grayscale? Or do you see the grayscale on the tiff output?
Would it be possible for you to provide a Workspace Template that reads in a small representation of the raster and either includes the source data or the feature cache?
