TweetSearcher Authentication Issue
  • July 11, 2017
  • 12 replies
  • 39 views
I am using TweetSearcher on FME Desktop 2016 to find tweets with a keyword and within a bounding box. I used my Twitter login details and it was working absolutely fine earlier.
However, since a few days, I am not able to use the same workbench and it returns an error
Received HTTP response header: 'HTTP/1.1 403 Forbidden' from 'https://api.twitter.com/oauth/access_token'
Could you suggest how can this issue be resolved. I can not find parameters in TweetSearcher to provide any access token.
Thanks in advance!
Best answer by jlutherthomas
As a temporary workaround, you may be able to use the Twitter API through a HTTPCaller.
In this question I mention how to I have spoken about how to authenticate with it, and then use the general Twitter search tool. I'm not sure what the limitations are from the authentication method. https://knowledge.safe.com/questions/45854/httpcaller-and-twitter-api-authentication-problems.html
danilo_fme
Forum|alt.badge.img+53
  • July 11, 2017
Hi @kanishk3687,
I installed the FME Desktop 2017 1.0.0 ( Build 17523 - Beta ) and tested the transformer but without success. The same error was show in the Log file :(.
I checked that the url to send request in twitter actually is: https://dev.twitter.com/oauth and not https://api.twitter.com/oauth/access_token that is generate by transformer TweetSearch.
I believe the reason the error is the URL.
Thanks in Advance
  • July 11, 2017
Hi @danillo_inovacao,
Thank you for quick response. I checked Twitter API and it mentions about access_tokens (https://dev.twitter.com/oauth/reference/post/oauth/access_token), however, I am not sure what is the workflow of FME TweetSearcher Transformer.
Strangely, it was all working fine a few days back. That means, there must be some recent changes within Twitter API.
mark2atsafe
Forum|alt.badge.img+59
My guess is that Twitter have changed something. I've flagged it as a high-priority issue with our developers and will get back to you.
danilo_fme
  • July 11, 2017
Hi @kanishk3687, like @Mark2AtSafe wrote the URL was changed. :)
colinhenderson
Hi @Mark2AtSafe any news on this one? All my workspaces with TweetSearcher are now failing with 403 Forbidden and causing me some headaches!
fmelizard
Forum|alt.badge.img+21
  • August 1, 2017
Hi @colinhenderson. Did you try @jlutherthomas's workaround suggestion?
mark2atsafe
  • August 1, 2017
Not yet. I've been off on vacation until today, so I will check it out and see what the status is.
mark2atsafe
  • August 1, 2017
It seems to be a bigger issue than you would expect. It means adding some extra OAuth support and that means updating both the engine and the interface. From what I can see I wouldn't expect a solution in the next couple of weeks (I just don't see an imminent fix). Can you go with the HTTPCaller workaround for now?
NB: It's not that we aren't doing anything - I can see lots of action going on in development. It's just going to be a longer time than I think anyone realized at first.
as an fyi, in the future I think transformers like these will end up being moved to the FME Store. That way they can be updated without you having to update FME every time (though having said that, the combination of OAuth and interface changes might have made it necessary anyway in this case).
colinhenderson
Was hoping to avoid the HTTPCaller workaround, but since that seems like the way forward for now I'll implement it.
fmelizard
  • August 3, 2017
Yes, dealing with the authentication issue has been more trying because Twitter's approach is different than the others (Google, Salesforce, Dropbox, etc) that we support now. We are close to having the new support into a Beta FME 2017.1.1 - and if you don't need this on FME Server we may be able to get you something sooner rather than later. Let us know your timelines (via live chat or support@safe.com) and we can advise on options. Our goal is to release 2017.1.1 in early Sept.
colinhenderson
Thanks Dale, will need this on server and timeline is pressing - this week! I have created a custom transformer which I'll share on the FME Hub as I needed some additional functionality as well - multiple tweet searching - so I was already wrapping the original transformer anyway.
