Trying to use SQLCreator or SQLExecutor with a workspace runner to run a SQL Stored procedure after upload completion
  • November 1, 2016
  • 144 views
brady
Hi all. I feel I am going around in circles.
I have a data update process uploading data regularly to SQL server. A requirement of this update is to run a couple of stored procedures on the uploaded data. I wish to run stored procedures that are entirely internal to SQL server after the upload is complete, rather than having to duck into MSSMS to trigger them. I don't require features or attributes to be passed back to FME.
Currently, I am have embedded my process in a workspace runner and use a single item creator to trigger it. I then hope to have the stored procedure(s) run/triggered from SQLExecutor or SQL Creator (if it will work in this fashion)
Something like exec dbo.'storedprocedurehere' only doesn't cut it. Comes back with a malformed statement.
Any help would be appreciated.
Thanks,
Brady
Best answer by todd_davis
From your error message, you just need to update the timeout within the SQLExecutor (under parameters). Your stored procedure is taken a while to complete and because FME doesn't get a response in that defined time, the query times out
todd_davis
Forum|alt.badge.img+23
  • November 1, 2016
brady
  • November 1, 2016
Hi @todd_davis, thanks for your answer. I have done that and it may very well have done the trick. The process seems to be called now.
Cheers
