Trying to use AttributeValueMapper to set one column's value based on the value of another column but it is not working. I can use it to map single values but I need to do it with ranges of values.
  • June 20, 2023
  • 38 views
michael_m
Forum|alt.badge.img+8
I am able to use AttributeValueMapper to translate single values (ie if col1 == 1 then col2 = 'A') but I need to get it to map ranges of values, something like
if (col1 > 0 AND col1 <= 50) then col2 = 'A'
I keep getting 'Invalid Test Expression' errors so it sounds like I'm not writing the conditional tests correctly but I cannot see where I'm going wrong. Here's an example:
Can anybody help me fix this, or point me at another way of setting a value in one column based on more than one possible value in another column?
Thanks,
Mike
Best answer by hkingsbury
I probably wouldn't do it in a AttributeValueMapper, id user either an AttributeCreator or AttributeManager. That above range should be fine, but you could also use the following logic
hkingsbury
Forum|alt.badge.img+67
  • June 20, 2023
michael_m
  • June 21, 2023
Thanks, hkingsbury. I did it in an AttributeManager and it's working well.
