Trying to extract faces from a solid
  • Jul 10, 2014 10:28 PM UTC
  • 271 views
ghareth
Hi I am new to using FME.
I have imported an IFC file in a reader.  I would like to take the ifcSpace geometry (an Aggregate Solid) and break it down to its constituent faces.
Any ideas please?
Thanks
Gareth
  • Jul 11, 2014 9:55 AM UTC
HI Gareth,
possibly a series of these transformers works.
1) Deaggregator to decompose the aggregate solid into individual solids.
2) GeometryCoercer to transform the solids into composite surfaces.
Geometry Type: fme_composite_surface
3) Deaggregator to split the composite surfaces into individual surfaces.
Split Composites: Yes
Takashi
ghareth
  • Jul 14, 2014 8:00 AM UTC
Thanks Takashi,
Works a treat!
gareth
jasperwis
Forum|alt.badge.img+19
  • Jan 17, 2020 3:10 PM UTC
How can you deaggregate a solid into the main surfaces without ending up with all individual faces?
I would like to merge all those coplanar faces. I have tried the SurfaceDissolver but it doesn't work.
solid_test.dwg
