Trying to create features from JSON (following JSONFragmenter)
  • August 11, 2017
  • 5 replies
  • 282 views
I'm trying to create (FME-)features from a JSON-ouput (source: JSONFragmenter).
I am not able to subtract/expose "geometry" and can't figure out why.
My JSONFragmenter parameters are:
JSON Query: json["features"][*]
Attributes to expose: id geometry
Can someone help me out ?
Example of JSON-output:
    "type": "FeatureCollection",
    "totalFeatures": 1681523,
    "features": [
            "type": "Feature",
            "id": "GBG.23662",
            "geometry": {
                "type": "Polygon",
                "coordinates": [
                            134465.638337,
                            192310.473928
                            134465.881025,
                            192308.624072
                            134470.076353,
                            192309.29684
                            134470.049217,
                            192308.49812
                            134474.971585,
                            192308.162248
                            134475.428289,
                            192311.290056
                            134472.498625,
                            192311.514824
                            134472.445377,
                            192310.982344
                            134470.684609,
                            192311.168712
                            134465.638337,
                            192310.473928
            "geometry_name": "SHAPE",
            "properties": {
                "UIDN": 334345,
                "OIDN": 294586,
                "TYPE": 2,
                "LBLTYPE": "bijgebouw",
                "OPNDATUM": "2005-09-05",
                "bbox": [
                    134465.638337,
                    192308.162248,
                    134475.428289,
                    192311.514824
Best answer by takashi
Hi @sdv, you have to flatten the JSON fragment to extract the members. Check these parameters in the JSONFragmenter.
  • Flatten Query Result into Attributes: Yes
  • Recursively Flatten Objects/Arrays: Set "Yes" if you need to flatten all descendant objects, "No" otherwise (flatten only one-level).
By the way, the document seems to be a GeoJSON dataset. You can also read it with the GeoJSON reader as features having a geometry and a set of attributes.
Forum|alt.badge.img+63
I don't have an immediate answer for you, but it looks like the output might be similar to what's discussed here.
  • August 11, 2017
  • August 11, 2017
Thank you for following up my question redgeographics . Indeed I have tried to study that topic to put me on the right track !
  • August 11, 2017
@takashi
This is how my workbench looks now
Now I'm able to see a 'geometry' field.
Just one (stupid...) question: can I use the FeatureReader to read the outcome of the JSONFragmenter ? I'm quite new to FME + can't seem to configure the FeatureReader for my purposes. Thanks !
  • August 11, 2017
If you intend to read the dataset as a GeoJSON document, I think just a single FeatureReader is what you need. Try connecting this FeatureReader to the CSV reader feature type directly.
