Trying to calculate average of response times in Minutes?
  • Oct 24, 2019 2:54 PM UTC
  • 65 views
I'm trying to calculate average response times for my city's fire department. I'm not sure which transformer is best to use? I've used the date time converter to change the data that is coming over in seconds to minutes but then I need to do a) calculate the average of those individual response times and/or b)subtract the difference between two fields and then c) calculate the average of the difference.
Thanks in advance for any help.
Best answer by jdh
The StatisticsCalculator can give you the Mean (Average) .
The DateTimeCalculator can give you the difference between two times.
jdh
Forum|alt.badge.img+41
  • Oct 24, 2019 3:10 PM UTC
  • Oct 29, 2019 1:47 PM UTC
Thank you! I will apply it in my workspace!
