truncated geodb_metadata_string!
owen
I have a workspace which updates file geoatabase metadata, reading the geodb_metadata_string.
This works fine for one gdb, but when I try it on a different gdb the geodb_metadata_string is truncated and missing most of the xml.
All I get is <?xml version="1.0"?>
<metadata xml:lang="en"><Esri><CreaDate>20140730</CreaDate><CreaTime>11460300</CreaTime><ArcGISFormat>1.0</ArcGISFormat><ArcGISstyle>INSPIRE Metadata Directive</ArcGISstyle><SyncOnce>TRUE</SyncOnce></Esri></metadata>
Ive tried using different metadata styles in arccatalog, but still does the same thing.
Any suggestions would be welcome! thanks
