Troubleshooting DateTimeConvertor rejected output
  • Jun 24, 2023 7:01 PM UTC
  • 8 replies
  • 116 views
Screenshot 2023-06-24 144730Screenshot 2023-06-24 144517I have an Excel dataset. I am translating two time attributes named "Occurred_time" and "Reported_time" with this format:%I:%M:%S%p to this format:%H:%M:%S.
Although it shows me the Preview Data, the result is rejected. I can't find what is the problem.
danilo_fme
Forum|alt.badge.img+58
  • Jun 24, 2023 7:27 PM UTC
Hi @marrysharif​
Could you share a example of your dataset?
Thanks in Advance,
Danilo
Hi @marrysharif​
Thanks in Advance,
Danilo
Oh yes, thank you.
I kept the required columns.
I have transformed the date columns with the same transformer and it worked.
@danilo_fme​ any idea?
danilo_fme
  • Jun 29, 2023 8:43 PM UTC
Hi @marrysharif​ How is your attributes?
Hi @danilo_fme​
I left that part for now because I can't find a solution. I shared a sample, an Excel. Have you seen it?
danilo_fme
  • Jun 29, 2023 8:52 PM UTC
I checked the file, but I didnt understand well.
The attribute Occurrence_Time is date format that you want %H:%M:%S
Yes correct. both time columns. and both date columns in mm/dd/yyyy. and this is my workflow. the date converting worked but the time converting got rejected.
  • Jun 30, 2023 12:23 AM UTC
I created a sample file and typed the data into it and it worked! I don't know what's wrong with my original excel!
