Trim .las using several line segments in a shp file format.
  • Nov 11, 2019 11:11 PM UTC
  • 38 views
alexandreaalves
Input: Several .Las and one SHP file with several segments.
Objective: trim the .LAS using the shp segments. Could exist more than one segment covered by the same .LAS. Buffer 0 and square.
Output: .Las trimed by the shp file segment and with the SHP file segment attribute name
sigtill
Forum|alt.badge.img+25
  • Nov 12, 2019 7:31 AM UTC
Hi @alexandreaalves
Reader: SHP - use Buffer on this to creat the polygons you want.
Reader: LAS
- Use a Reprojector on both SHP and LAS to the same coordinate system
- Use a Spatialfilter to filter out the points within the SHP-files
Writer: AS - and take the fanout-filename from a parameter from the SHP-file.
If you want an example-workspace, please submit a single LAS and a single SHP.
