Transposing Data - Making Rows into Columns and Naming Columns Based on Attributes
Process_OverviewI'm attempting to transform the input Rain Gauge data set to the desired output as shown in the above inserted image but I'm at a loss on how to proceed?
The important factors are:
  • The time period is defined by the user, in this example 01/01/2022 - 10/01/2022 and the output table needs to include all days in that range.
  • The input Rain Gauge data only contains data for when it rained so not all dates are included.
  • I need to some how produce a column per Rain Gauge reference, then look up the associated rain fall value for each of the days and populate the new table structure.
  • The number of rain gauges can vary.
I have completed the process of creating a list of all dates for the requested time period.
I can't begin to fathom how to manipulate the data as shown and explained above.
If completing this in Excel I would have created a pivot to produce the table below:
 Example_Pivot
Any help will be gratefully received!
Thank you.
Best answer by geomancer
Something like this?
RainGauges
geomancer
Forum|alt.badge.img+50
  • June 9, 2022
RainGauges
  • June 9, 2022
RainGauges
Thanks for the amazing reply.
I can see in the first AttributeManager you've set up the Output Attributes as RG01 and RG02. If I had further RG's e.g. RG03, RG04 etc I have to manually add them to this transformer? Could that instead be automated by generating a unique list of RG references from the Input Data?
geomancer
  • June 9, 2022
The alternative (lower) route uses @Value(RG_Ref) to define attribute names. That creates unexposed attributes RG03, RG04 etc.
Afterwards you will have to explicitly expose those attributes. For this you can create a text document with all unique RG-values from the input file (take a look at the DuplicateFilter), and manually import this document in the AttributeExposer to expose all these attributes. Next you can process the whole input file.
  • June 9, 2022
Great idea, I used a DuplicateFilter to create a unique list of the RG_Refs in the CSV Reader. Then imported that into the AttributeExposer which works.
What about the AttributeManager on the upper route in the bookmark named - Define Attributes? Into this attributemanager I may need to add 50+ rain gauge attributes and set up the conditional formatting. Is there away of bulk completing that?
geomancer
  • June 9, 2022
Hi @rob_nason​ , the AttributeManager on the upper route in the bookmark named Define Attributes you can also perform an Import, but I suspect this will only import the attribute names, not the definitions of the conditional values.
If somebody has other ideas, please feel free to participate!
  • June 9, 2022
The import function does indeed bring in the attribute names but I can't see a way of populating the conditional values other than by hand.
Perhaps a price I have to pay, your workflow is still a big improvement over the current Excel process!
