Transposing attributes similar to Excel
  • Apr 22, 2016 4:01 PM UTC
  • 76 views
femo
Hello,
I am reading a folder containing various Excel files of the same schema. The difference between the files is the date and the content, the structure is always the same. My goal is to create a line diagram in a new Excel file. I want to use the "ChartGenerator".
My Problem now is to prepare the data to be used within the ChartGenerator:
I will have a bunch of records as illustrated in the "Start" section of the above pic. For every additional date I will have an additional record. I need to convert the data as illustrated in the "End" section. For every additional date I will need an additional column.
The various existing Posts regarding transposing data do not seem to tackle my issue.
Any ideas?
nielsgerrits
Forum|alt.badge.img+67
This article might help.
This custom transformer should be included by default in FME as an out-of-the-box transformer @daleatsafe!
https://hub.safe.com/transformers/attributetransposer
fmelizard
Forum|alt.badge.img+22
  • Nov 15, 2018 1:53 AM UTC
Yes, this is a very good one. And I think if we included it, if Feature Caching was on, we could do something about figuring out the resulting schema too. Would you mind posting this as an idea? (If I do, it seems a bit disingenuous) Thanks for flagging it.
Will do. And it DOES work (deleted my previous comment). Inspector always gets me when it doesn't show all attributes that have been added dynamically, so I thought it didn't work at first glance. It was a long day :)
