Transpose Records based on intersection
  • May 10, 2018 8:28 PM UTC
  • 22 views
I have points where each point has 5 points which all share the same geometry and share the one field name but with different values in that field between the records.
How do I transpose those different field values down into a single geometry where they intersect, while keeping the field values?
jdh
Forum|alt.badge.img+41
  • May 10, 2018 8:40 PM UTC
Have you considered a NeighbourhoodAggregator with Generate List?
You can then turn the aggregate into a single point using the GeometryPartExtractor with the expression number(/geometry/geometry[1]/@fme_id) (Returns the 1st point in the aggregate)
