I used the "AppearanceRemover" first, then the "AppearanceSetter" and wrote both an fbx and an obj file for testing. When viewed in the inspector, the obj file is transparent, the fbx file unfortunately is not (refer to attachment).
Hello I have found the problem. In the parameters I set the parameter "Embed Textures" to “No”. By adjusting the setting to "YES", the FBX file is also transparent. So the question would actually be "How do I create a transparent FBX file if I don't want the texture in the file?"
Ahh nice discovery, Thanks for sharing. Sorry I didn’t follow up with you
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
