Translation from OpenStreetMap OSM to Shapefiles: Building line from Nodes failed
  • Sep 18, 2014 6:28 PM UTC
  • 0 replies
  • 29 views
I am trying to translate from an OpenStreetMap OSM to shapefiles. The log is displaying "Building line from nodes failed: Node id 'x' is not an integer."
I was just curious about what is causing this and what I could do to fix the issue?
