Translating KMZ to GeoTIFF - issues
  • September 25, 2013
  • 107 views
I am an infrequent user of FME and am having issues with converting a KMZ to GeoTIFF. The KMZ was created using the Map to KML tool in ArcGIS 10.0, and it displays correctly when I preview it in the Universal Viewer. When I try to run it through the Quick Translator, I get the following error message:
GEOTIFF writer: Failed to obtain a raster geometry from the feature. Only features with raster geometry are expected by the GEOTIFF writer
Feature Type: `Placemark'
Geometry Type: Unknown (0)
I've tried running the translation with different settings in Parameters but it will not work. Does anyone have any ideas on how to proceed?
The KML/KMZ dataset usually contains several feature types, the Quick Translator seems to send all features (including non-raster) to the writer. I think the error occurred when the GEOTIFF writer received a non-raster feature.
I'm not sure how we can avoid it in the Quick Translator, but using the Workbench could be a workaround.
Add a "Google Earth KML" (OGCKML) reader and a GEOTIFF writer to the workspace, and then send only the feature containing the raster (probably "GroundOverlay") to the writer.
Takashi
fmelizard
Forum|alt.badge.img+21
If you are unsure which feature type is the raster you can use the geometry filter to grab the raster.
davideagle
Forum|alt.badge.img+22
As Takaski suggests the Quick Translator is not flexible enough to resolve this issue, you'll need to switch to Workbench. You are attempting a process that may have vector data in the source KML file and the GeoTIFF writer must recieve Raster data. So in workbench you need to add a KML reader and then a GeometryFilter to route any Vector features to a transformer caqlled the Rasterizer, this will turn all your graphics into rasters that can be sent to the GeoTIFF writer without getting the error you're seeing.
