Translate xml TransXchange data to another format
  • Jun 20, 2017 11:17 AM UTC
  • 122 views
Has anyone had experience with the TransXchange transport information format used in the UK ?
I'm unable to get the xml reader in Workbench to read/ translate the data into another format (i want to import into a GIS)
This is the schema:
ttp://www.transxchange.org.uk/schema/2.4/TransXChange_general.xsd
and the following the error message
Opening the XML reader with source dataset 'F:\\FME_processing_data\\Carto_jobs\\TravelineCymru\\NewAdventureTravel63-Brecon-Sennybridge-Ystradgynlais2_TXC_2016510-0220_PWAO063.xml'
The uri-map document 'C:\\Program Files\\FME2017\\xml\\urimap\\gml_aixm.xml' is being used to map from URI to URI
The uri-map document 'C:\\Program Files\\FME2017\\xml\\urimap\\gml_citygml.xml' is being used to map from URI to URI
The uri-map document 'C:\\Program Files\\FME2017\\xml\\urimap\\gml_inspire.xml' is being used to map from URI to URI
The uri-map document 'C:\\Program Files\\FME2017\\xml\\urimap\\gml_urimap.xml' is being used to map from URI to URI
Unable to configure the XML module to read the XML dataset. No <xrs:switch> item in the xrs document 'C:\\Program Files\\FME2017\\xml\\xrs\\xrs.xml' matched the XML dataset 'F:\\FME_processing_data\\Carto_jobs\\TravelineCymru\\NewAdventureTravel63-Brecon-Sennybridge-Ystradgynlais2_TXC_2016510-0220_PWAO063.xml'
The XML format could not be determined by examination. Try entering a feature path into the "Elements to Match" parameter, specifying an xfMap, selecting an XRS, or using a more specific reader
The XML Module halted on error, see the logfile for details
Cheers,
Bruce
revesz
Forum|alt.badge.img+22
  • Jun 21, 2017 4:51 PM UTC
Have you selected the nodes to import in Parameters/Elements to Match? If you click on the button with ... you can select the XML nodes in the tree structure, eg.: TransXChange/Routes/Route
I tried this sample XML and it works.
  • Jun 22, 2017 1:38 PM UTC
Hi, and thanks for this.
I've managed to extract the "Track" information, and starting to create vertices from the easting and northing attributes.
A work in progress, but I'm getting there ;-)
  • May 3, 2018 9:00 AM UTC
Hi @beedge144 did you manage to get the Operating Profile days out? It comes up as an attribute like: OperatingProfile.RegularDayType.DaysOfWeek.Wednesday with no value..
