Transforms: Scaler y CoordinateSystemSetter
  • Mar 25, 2014 3:16 PM UTC
  • 31 views
Hello,
I have some small questions:
1 - If I use a transformer "Scaler" and another "CoordinateSystemSetter". Is there a difference in behavior depending on the order?. I mean, is it important which placed first and which second?
2 - I want to transform data from a data base Smallworld PostGIS data base. the first is in centimeters, and the second is in meters. Is it necessary to use a "Scaler" or "CoordinateSystem" transforms?
3 - Is it possible that the same template to work on a version of Smallworld data base and not work on another version of the same database?
thank you very much
regards
Luis
gio
Forum|alt.badge.img+15
  • Mar 25, 2014 5:10 PM UTC
http://fmepedia.safe.com/articles/How_To/Smallworld-3-x-ACP-reader-writer
might help you out?
Greets
Gio
