Hello,
I have GML file with polygons. Polygons are defined by coordinates inside LinearRing attribute. There are some other attributes, one of which is an ID of a polygon.
I want to transform that GML to DXF format (only polygons and IDs (as texts) which have to be placed inside the polygons) and I have managed to do so, but I have a problem with some funny shaped polygons for which ID falls outside the polygon.
What do I have to do to make sure those texts (IDs) in DXF are put inside corresponding polygons?
Thanks in advance for any suggestions.
Best regards!
