Transformer full join tables - 2017.1 version
  • Aug 9, 2019 1:52 PM UTC
  • 68 views
user01
Hello,
I'm new in practicing FME and didn't find any answer to my question.
I'm using FME version 2017.1 and I want to make a FULL JOIN between 2 tables resulting of the transformation of PostgreSQL (Postgis) database tables.
FeatureJoiner transformer would be the one I need but only avalaible since version 2018. I heard about others transformers but joining only from common columns (inner join,....).
Any idea ?
Thank you !
  • Aug 9, 2019 1:57 PM UTC
If possible, you'll get the best performance by using the SQLExecutor / SQLCreator, by far.
Otherwise look at the following
  • FeatureJoiner (not available in FME 2017)
  • FeatureMerger
  • InlineQuerier
erik_jan
Forum|alt.badge.img+26
  • Aug 9, 2019 3:09 PM UTC
@david_r listed most of the usable transformers.
From the list SQLCreator would be the best if the tables are in the same database.
Another option would be creating a view in the database, using the join, and using the view in the PostGreSQL reader.
