Transformation or Python Script?
  • Jun 18, 2021 12:14 PM UTC
  • 65 views
plynn
Forum|alt.badge.img+10
I have two things that I am trying to accomplish with the current feature/attributes that I have joined. For each row of data, I need to write out 5 new rows. Also, in the new rows, some of the column values are the column names of the input feature.
Here is an example: (Attribute Name: Attribute Value)
input: ASSETNUM: 12345, VLVCOND:Good, TRNSOPEN:10, OPENDRTN: Clockwise, STRUCTUR:No, SURCOVER: Blue, INSPECTOR:Joe Smith
Output: ASSETNUM:12345, METERNAME:VLVCOND, OBSERVATION:Good, INSPECTOR:Joe Smith
ASSETNUM:12345, METERNAME:TRNSOPEN, OBSERVATION:10, INSPECTOR:Joe Smith
ASSETNUM:12345, METERNAME:OPENDRTN,OBSERVATION:Clockwise, INSPECTOR:Joe Smith
ASSETNUM:12345, METERNAME:STRUCTUR, OBSERVATION:No, INSPECTOR:Joe Smith
ASSETNUM:12345, METERNAME:SURCOVER, OBSERVATION:Blue, INSPECTOR:Joe Smith
Any help would be greatly appreciated.
Thanks.
Best answer by ebygomm
This is the sort of workflow you would need
Capture
Forum|alt.badge.img+54
  • Jun 18, 2021 1:39 PM UTC
You should be able to do this with an AttributeExploder
Is your input text as per the example, or do you have a feature that has attributes ASSETNUM, VLVCOND etc. like this
Capture
plynn
  • Jun 18, 2021 1:55 PM UTC
Capture
The input is a feature that has attributes like you have it shown above.
  • Jun 18, 2021 1:56 PM UTC
Capture
plynn
  • Jun 18, 2021 3:03 PM UTC
Capture
That worked perfectly. Thank you so much for your help.
