Transform grey-scale TIFF to specified colours
  • Mar 12, 2019 1:15 PM UTC
  • 5 replies
  • 371 views
fbinneman
Hi All
I am trying to convert a grey-scale raster (TIFF file) to one where the pixel colour is based on a scale of the Band 0 value that is specified for each pixel, where green is used as the lowest value and then scales to red for the highest value. The only transformer that I found where I can set the colour is the GradedColorizer.
I first used the RasterCellCoercer to get to the Ban 0 value (_band{0}.value) for each pixel and then uses in the the GradedColoriser. Once this transformer finishes its operations on the data, it gets sent to an ImageRasteriser to recreate a raster, which is then sent to a TIFF writer. The workbench file is attached here: . A test image can be found here: .
The workbench however fails at the ImageRasteriser, stating INVALID_VECTOR_GEOMETRY_COLOR as reason.
I must add that my understanding on raster bands are rather limited. I have also tried other transformers to keep the image as an image, and work with the Alpha band, but this seems to require more knowledge than I have.
Can anyone perhaps tell me what I am doing wrong here? I have had quite a look at the other questions on the knowledge base but was not able to find anything quite similar (and probably as basic as I am attempting to do).
Any help would be appreciated.
Best answer by takashi
Hi @francois_binnem, I think what you need is raster palette operations. The RGBGradationCalculator from FME Hub might help you to generate an appropriate palette definition.
See the attached workspace example: convert-gray-scale-to-color-image.fmwt (FME 2018.1.1)
Hope this helps.
  • Mar 12, 2019 2:12 PM UTC
Hope this helps.
fbinneman
  • Mar 13, 2019 7:20 AM UTC
Hope this helps.
Hi @takashi, thank you so much! It worked great!
Hello. I also need your advice, but the file "convert-gray-scale-to-color-image.fmwt" is no longer available! Could you add it? Thank you
fbinneman
  • Jun 8, 2021 11:37 AM UTC
Hi Samuel. I have an edited version of that file, which I have attached below my initial question now. Hopefully you can make use of that. Regards
Hi @fbinneman​ , thank you so much!
