Transform attribute after list indexer
  • Feb 18, 2022 8:43 AM UTC
  • 81 views
I get data via API in a JSON format. The values from "Points" need to be stored in seperate attributes. I managed to do so with JSON Fragmenter (json["points"][*]). With list indexer I can then store each index (0 & 1) to an attribute. But I can not transform then this attribute with DateTimeConverter.
In the log I saw, that the list structure still exists in my dataset. I also found this information in the Feature Information (see screenshot).
How can I actually transform the list into a proper attribute?
JSON Structure:
  "name" : "xy",
  "modified" : "2022-02-16T10:16:53.066Z",
  "points" : [
   [ 1642633200000, 123.99 ],
String replacer Output vs. Feature Information:
Best answer by takashi
Hi @hodelc​ , looks like the datetime value e.g. "1642633200000" is an elapsed time from the epoch in milliseconds. I think the DataTimeComverter could recognize it as a valid datetime value from epoch if you converted it to the value in seconds.
datetime = datetime / 1000
  • Feb 18, 2022 9:10 AM UTC
  • Feb 18, 2022 9:32 AM UTC
Hi @Takashi Iijima​
Thanks, this solved my problem! I did the calculation with ExpressionEvaluator_Output
