Transform a PostGIS geometry in a Smallworld geometry
  • Aug 28, 2013 3:48 PM UTC
  • 109 views
Hi, I´ve PostGis tables whith 3 geometric fields (with different projections), The recordas can be points, lines or areas. I need to transform this geometries (one of the fields) in a Smallworld Geometry...but i don´t know how..
I would be very grateful if someone could help me
Thanks
  • Aug 29, 2013 7:26 AM UTC
I do not know what a Smallworld geometry really means in your context, could you please expand? What type of geometry is allowed?
David
  • Sep 4, 2013 5:32 PM UTC
Hi, thanks for replying.
Sorry I responded so late but I have problems with my fme.
I meant if, for example, I have a reader from a postgres table (which represents a line and its attributes).On the other hand I have a table of Smallworld whose main geometry is "route".
How do I indicate on my workbench the relationship between geometry?
A postgres record has 3 geometric fields (different projections, but i dont know if these fields are important)
Thanks, and sorry if I have not explained my question well
geolassi
Forum|alt.badge.img+8
  • Sep 13, 2013 5:43 PM UTC
This instruction can be applied to Smallworld FME Translator (not the SBS plugin). Getting the geometry into Smallworld is done with an attribute called smallworld_geometry{0}.sworld_name. You can use AttributeCreator to create the attribute smallworld_geometry{0}.sworld_name and give route for the value of the attribute. Just to be sure, you should expose attribute sworld_geometry{0}.sworld_name from the feature type properties and Format Attributes tab.
If you have multiple geometries then smallworld_geometry{1}, smallworld_geometry{2}, etc. can be used.
