Transferring georeferenced images to a Geodatabase
  • Apr 3, 2019 6:42 PM UTC
  • 220 views
fme_noob
Hello Everyone,
I have a folder full of georeferenced image files that was done in ArcMap. It includes the image type (png/tiff/jpg) and other files that has the georeference data in it like the .aux.xml and .pgwx. Would it be possible to have FME move all of this data to a GDB? I'm not sure how this works with the multiple files associated with one image.
Best answer by owen
If you use a jpg reader for example, FME will automatically pick up the georeferencing info. Would suggest you read the whole folder, once for each format
owen
  • Apr 3, 2019 8:23 PM UTC
Hello, it should be the case of reading them all and writing to gdb using the Esri Geodatabase (File Geodb Raster Dataset) writer. Owen
fme_noob
  • Apr 4, 2019 1:22 PM UTC
Hey Owen, Do you mind going into more detailing about reading them? How would you read the multiple files representing georeferenced images in a folder?
owen
  • Apr 4, 2019 2:42 PM UTC
fme_noob
  • Apr 4, 2019 3:40 PM UTC
Ah ok I think Im getting the gist of it now. I was able to successfully move one image to the GDB. It doesnt appear to be georeferenced correctly but I'll play around with it.
