Tranposing data into new format
  • July 11, 2019
  • 11 views
I am trying to transpose data. I already read some posts about how to transpose a table using FME. But I am not able to get what I want.
I have the following table within FME:
I want to transpose the data so I get the following format:
So I don't need my column names. This is just an indication for myself.
Does anybody know which transformer(s) I need to use?
Best answer by takashi
If I understand the requirement correctly, this workflow does the trick.
  • July 11, 2019
  • July 12, 2019
@takashi, it indeed does exactly what I need! Thank you so much :-)
