Total count of features from dataset A within certain proximity of features from dataset B
  • Apr 20, 2020 7:35 AM UTC
  • 171 views
lcw
Hi all,
What's the best way of getting FME to populate an attribute field in ArcGIS geodatabase point feature class A (areas of interest) with the total count of features from dataset B (assets)? I.e. find the total number of assets within 10m distance of sites?
I thought the Neighbourhood Finder or Point on Point transformers followed by a Statistics Calculator should do the trick, but can't get it to work.
Thank you!
Best answer by ebygomm
The neighbourfinder with Generate List ticked under attribute accumulation and then a listelementcounter should do the job here. No need for a statistics calculator
itay
Forum|alt.badge.img+19
  • Apr 20, 2020 7:55 AM UTC
Hi @lcw,
You are on the right track, just make sure one of these transformers creates a list and then you can count the number of list elements (ListElementCounter) for your result.
Hope this helps.
Forum|alt.badge.img+54
  • Apr 20, 2020 8:30 AM UTC
Hi @lcw,
Hope this helps.
A list element counter counts the number in the list - no need to add 1
A feature with attributes list{0} and list{1} will give a result of 2 in the listelementcounter
  • Apr 20, 2020 8:31 AM UTC
lcw
  • Apr 20, 2020 11:01 AM UTC
Fantastic, that worked a treat! Thanks for the fast reply and excellent screen grab. Much appreciated!
