To invert Y/Z AXIS for a correct OBJ
  • Oct 31, 2021 1:07 PM UTC
  • 160 views
giuseppecfgeo
Forum|alt.badge.img+5
Hey community! how can I convert a point cloud in this sense? When I put my obj in Unity I have this problem....
itsmatt
Forum|alt.badge.img+48
  • Nov 1, 2021 8:22 AM UTC
You can use an CoordinateSwapper (http://docs.safe.com/fme/2020.0/html/FME_Desktop_Documentation/FME_Transformers/Transformers/coordinateswapper.htm) to swap the axis before writing out. If you switch Y <> Z you should get the result you're after.
