TIN Surface to Solid for AutoCAD
  • Oct 2, 2019 9:33 AM UTC
  • 333 views
Hello,
I have created using TIN Generator a TIN Surface. The output geometry originally is IFME Mesh. I want to create a solid for AutoCAD Civil 3D.
I have tried everything I can think of (incl. setting Geometry Coercer to brep solid) but the result is this:
It still appears as a polyface mesh in AutoCAD and in FME the outer surface remains a mesh.
Any ideas?
Thank you.
George
Best answer by itsmatt
Make sure you use the RealDWG writer. The ACAD writer does not supporting writing out solids to AutoCAD (https://knowledge.safe.com/articles/21601/autocad-dwg-which-format-should-i-use.html).
If you want to avoid the mesh geometry, you can try Coercing the mesh first into a CompositeSurface and then into a Brep solid.
itsmatt
Forum|alt.badge.img+48
  • Oct 2, 2019 10:05 AM UTC
