Tiler transformer size by meters
  • Dec 19, 2018 8:57 PM UTC
  • 84 views
gcarmich
Participant
I would like to use the Tiler transformer to create 100x100m tiles. How do I specify this? They only size option I see is listed as "ground units".
Best answer by redgeographics
The units used are whatever units your data is in. So if your data is in meters, the Tiler will interpret the tile size as meters.
Forum|alt.badge.img+63
gcarmich
Participant
  • Participant
  • Dec 19, 2018 9:21 PM UTC
How do I define or tell what units my data is in?
jdh
Forum|alt.badge.img+41
  • Dec 19, 2018 10:46 PM UTC
It's based on the projection/coordinate system.
If you data is in LL-WGS84, the units is degrees, it it's in most UTM projections it's meters.
The coordinate system gallery lists the units for each coordinate system, if you don't know.
jdh
  • Dec 19, 2018 10:49 PM UTC
If your data is not in meters, you can reproject to _AZMEA_ or other metered coordinate system that best suits your data, run the Tiler, and then reproject back to your original coordinate system.
If your don't want to reproject your data (and there are degradation issues around floating point values) you can use a boundingBoxAccumulator, reproject that, tile it, reproject to the original coordinate system, and use the results as a clipper on your original data.
