The Things Network integration - airquality sensor data
  • Mar 26, 2020 1:20 PM UTC
  • 6 replies
  • 121 views
stefanh
Forum|alt.badge.img+8
There are some air-quality sensor in the area I work. These are connected with the LORA-network and The Things Network (TTN).
Data can be accessed by the MQTT-protocol. However I have no experience with this.
I found the MQTTReceiver (which uses an old Python version) and MQTTConnector.
I tried both Transformers with the settings I received; like this:
Unfortunately it is not working. The error I get
Anyone experience with this?
Thanks!
Stefan
Hi @stefanh,
The MQQTReceiver on the FME Hub is not supported by Safe. The official tool to use is the MQTTConnector which is developed and maintained but us (see the publisher Safe Official).
Can you please share what error message you see in the MQTTConnector?
Thanks
stefanh
  • Mar 26, 2020 4:10 PM UTC
Hi @stefanh,
Thanks
Thanks!
I get a rejection. The message is:
I created a web connection like this; but I don't see an option to test it.
As mentioned earlier I have no experience with MQTT, so I do not know what the put in every parameter in the MQTT parameters. I have the following
Thanks!
I get a rejection. The message is: 0684Q00000ArM6AQAV.png
According to this https://www.thethingsnetwork.org/docs/applications/mqtt/api.html your Web Connection seems to be ok as long as the username & password matches the Application ID & Access key.
Can you confirm that the device you are trying to send messages to is activated yet?
According to the API doc, you can subscribe (Action = Receive in the MQTTConnector) to this topic to receive activation messages:
"+/devices/+/events/activations"
link to doc: https://www.thethingsnetwork.org/docs/applications/mqtt/quick-start.html#receive-activations
Here's how I would set up the MQTTConnector to do that:
When you are sure that your device is activated you should be able to send/receive messages to it.
Let me know how this goes!
stefanh
  • Mar 27, 2020 7:17 AM UTC
Hi @stefanh,
Thanks
Thanks again for your reply! I tried these settings, but still no success.
The error I get is:
In the rejection inspection it says:
"Timed out connecting to the broker"
stefanh
  • Mar 31, 2020 11:23 AM UTC
Hi @stefanh,
Thanks
I solved the issue; the tcp-port was not open.
When the port was opened I got it working with your solution.
Thanks
Thanks
Thanks for the update! This is great news!
