As the “LanduseRoad” layer is generated by the workbench, this layer is wanted to be copied and pasted to another layer but two errors are introduced:
1. “The number of points is less than required for feature”
2. “linesting or polyboundary is self-intersecting
What might be the issue here?
Thank you
Best
Jamal
