the mobile text message was always cut off by the ampersand “&”
  • Aug 26, 2019 10:17 PM UTC
  • 197 views
syang
I tried to use TwilioSMSSender to send a web link text message to my mobile. The text message was http://qgsp.maps.arcgis.com/apps/webappviewer/index.html?id=56fc6ae6f9cb4d5b8aaa554126cc50e0&find=260819MKY1 . However, the text message was always cut off by the ampersand “&”, which means my text message received was http://qgsp.maps.arcgis.com/apps/webappviewer/index.html?id=56fc6ae6f9cb4d5b8aaa554126cc50e0 .Any suggestions will be appreciated. Thank you.
Best answer by syang
@manjeetgrang​ using %26 replace "&"
  • Aug 27, 2019 7:26 AM UTC
It could be that the ampersand is interfering with the API. Maybe try using the TextEncoder set to URL encoding first.
syang
  • Aug 27, 2019 11:01 PM UTC
@david_r It solved the problem, thank you very much!
HI IAM FACING SAME PROBLEM . CAN YOU PROVIDE ME SOME ADVICE HOW TO DEAL WITH & IN TWILLIO
syang
  • Sep 27, 2021 4:57 AM UTC
