The easiest way, how to change coordinate values of feature?
  • Jan 15, 2018 9:52 AM UTC
  • 32 views
lazarlubomir
Forum|alt.badge.img+11
Hello everybody,
please, I try to find the easiest way how to recompute coordinate values of feature.
For example - the line has only two vertices in X/Y - 558000,695855 ; 558300, 655964. I need to change value of Y coordinate directly - e.g. to add value 27000 to Y value. So the resulted values should be in X/Y 558000,722855 ; 558300, 682964.
I will appreaciate all tips!
Thank You!
Lubo
Best answer by takashi
Hi @lazarlubomir, the Offsetter transformer might help you.
  • Jan 15, 2018 9:56 AM UTC
lazarlubomir
  • Jan 15, 2018 4:18 PM UTC
Thank You so much!
