The best way how to check encoding of TXT file
  • Nov 29, 2019 11:11 AM UTC
  • 4997 views
lazarlubomir
Forum|alt.badge.img+11
Hello everyone,
Im thinking about the best way how to check encoding of ASCII (.txt) file in FME Desktop.
But, is is possible, at all?
Now, I have TXT reader in my workspace nd then I use stringsearcher transformer to check unsupported letters. Im not sure if it is the best way...
Thank You so much!
Lubo
Best answer by david_r
Unless the text file contains a BOM (byte-order mark) in the first two characters to indicate Unicode, there really is no definitive way of knowing which encoding a text file contains. If you can make a lot of fairly hard assumptions, you can assume that it's probably this or that, but in reality even that is stretching it a bit.
If the text files does contain a BOM header, FME should be able to auto-detect it correctly, although it may depend on your specific use case.
See also: https://softwareengineering.stackexchange.com/questions/187169/how-to-detect-the-encoding-of-a-file
  • Nov 29, 2019 11:21 AM UTC
lazarlubomir
  • Nov 29, 2019 3:24 PM UTC
@david_r,
thank You so much, I thought that the solution is hardly reachable...
