text replace
  • May 14, 2019 7:48 AM UTC
  • 77 views
terezia86
I would like to replace the texts in my excel list (possibly also different formats).
for example:
in Python it looks like this:
in Attribute "street"
def replace(field):
if"straße" in field:
return field.replace("straße", "str.")
elif"Straße" in field:
return field.replace("Straße","Str.")
elif"strasse" in field:
return field.replace("strasse","str.")
elif"Strasse" in field:
return field.replace("Strasse","Str.")
elif"ä" in field:
return field.replace("ä","ae.")
elif"ö" in field:
return field.replace("ö","oe.")
elif"ü" in field:
return field.replace("ü","ue.")
else:
return field
which transformer should I use, and how? I have no experieces with it.
Thanks
Best answer by david_r
You can use the StringReplacer, and possibly also the StringPairReplacer.
  • May 14, 2019 7:53 AM UTC
terezia86
  • May 14, 2019 8:18 AM UTC
Hi david_r,
thanks for reply!
Could you explain me more, pls?
How should I write it? How to edit the parameter?
Thanks
  • May 14, 2019 8:24 AM UTC
Hi david_r,
thanks for reply!
Thanks
I would start by looking at the manual for these two transformers, it's very well explained there:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/stringreplacer.htm
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/stringpairreplacer.htm
If you have further questions, feel free to post them here.
