Testing if unique values have different values in another field.
  • January 11, 2021
  • 121 views
Hi, How I can test if unique values have different values in another field. Example:
Field1 Field2
AB1.... 1
AB1.... 2
AB3.... 3
AB4 ....4
AB5.... 5
AB6.... 6
AB7.... 7
AB8.... 8
So, AB1 has in field 2, values 1 and 2. So I want to filter that separately. Values can be changed, so I want generic solution. Can anyone help me with that? Thank you
Best answer by rahulsharma
Hi @gisgis2014devel​
I think using a DuplicateFilter transformer on Field1 you should be able to get the desired result.
DuplicateFilterNOTE: As long as the Field Name or Attribute is same, this would work with any dataset(dynamically)
rahulsharma
Forum|alt.badge.img+10
  • January 11, 2021
Attached fmwt file.
Using two statistics calculators and two testers will give you the result you want I think. You can do the same with multiple aggregators, matchers, or any other blocking (group by) transformer that creates a count.
Capture
Thank you, it does what I want in a simple way.
jlbaker2779 wrote:
Attached fmwt file.
Capture
Thank you a lot :). I will try your solution as well. Also rahulsharma solution worked well.
