TestFilter Parameters
I am a new user trying to split out TRUE FALSE values contained in column Web with the TestFilter, but can't seem to hit on the correct Test Condition. Each time I Run Translation everything goes through to Unfiltered. It would appear that the TestFilter isn't recognising Alpha characters.
When I change alpha TRUE to numeric 1 then the TestFilter works fine.
This doesn't help when I have Alpha Numeric values such as 06HaaR.
I would value assistance in this regard please.
Cheers
Best answer by giarcnomis
As I said, "I am a new user" and am feeling my way and don't understand a lot of the terminology.
After playing around with the parameters with a bit of trial and error, I have stumbled onto the answer.
The operator field needs to be set to Contains Regex.
My issue appears to be resolved. Cheers
pratap
Forum|alt.badge.img+11
  • July 27, 2018
I think, Web column have formula instead of value.
Connect the reader to inspector and see the contents of web column initially. Later pass the respective value instead of "FALSE"
Pratap
  • July 27, 2018
pratap wrote:
Pratap
All cells contain values and no formulas
pratap
  • July 27, 2018
Can you send sample data of the 2018-07-27-14-14-32.png to review and suggest
pratap
  • July 27, 2018
Sample data is required to check... this is something strange than expected.
  • July 27, 2018
Forum|alt.badge.img+39
  • July 27, 2018
It's likely that there are hidden/non printing characters in your column which is why the equals condition isn't working
