TestFilter not working as expected
  • September 19, 2017
  • 99 views
I have a TestFilter query that works on most dwg layer names but not on a number of layer names.
There are approx 70 Dwg files with approx 300 feature names, most work but one (Tree) does not??
I tried two queries
Else IF @Value(fme_feature_type) IN AF_Tree,G902TREELINE,G902DTREE3,G903TREE_DECIDUOUS,00__TOPO__TREE__LINES,00__TOPO__TREE_CONIFEROUS_SPREAD_SYMBOL
AND
Else IF @Value(fme_feature_type) = AF_Tree
Else IF @Value(fme_feature_type) IN G902TREELINE,G902DTREE3,G903TREE_DECIDUOUS
I keep getting G902DTREE3 rejected into the Unfiltered layer??
Any recommendations would be appreciated.
oscard
Forum|alt.badge.img+23
Does your TestFilter look like this?
I have tried with some data and it's working as expected.
first of all, check carefully whether the layer name you have set to the transformer parameter is strictly equal to the actual layer name (i.e. value of "fme_feature_type"). Isn't there a difference in character case? Isn't there an excess leading/trailing space? and so on.
courtney_m
Building on @takashi's comment, to ensure to rule out the Case sensitivity, you can test the Upper Case value of the the fme_feature_type - Just make sure your test value is in ALL CAPS - see the screen shot below.
