tester
  • Feb 27, 2020 10:45 AM UTC
  • 35 views
Hello!
I would like to make a test on my datas. These are points , that have a _pontID and there is a _MIN, MAX and _MEAN values. I want to filter those points where _pontID = _MIN and _pontID = _MAX_uj and _pontID = _mean_pontssz.
The problem is that the query only gives back the right solution with _MIN.
Here is the definition:
The values are like:
Can you help me, what can be wrong?
Best answer by erik_jan
I think what you are looking for is a 3 line test in the Tester:
_pointID = _MIN
OR _pointID = _MAX_uj
OR _pointID = _mean_pointssz
That will get all features that pass one of the test clauses.
Hope this helps.
erik_jan
Forum|alt.badge.img+26
  • Feb 27, 2020 1:54 PM UTC
_pointID = _MIN
Hope this helps.
