Test based on attribute operator included
  • Nov 17, 2019 8:22 PM UTC
  • 7 replies
  • 241 views
alc33
Forum|alt.badge.img+14
Hi!
I have 2 attributes, one with the value to test and one with the test.
I would like to do an automatic test based on this 2 attributes in order to keep or not entities.
I tried expression evaluator and attribute validator but I don't find the good syntax.
Indeed, on my second attribute I could have a mathematical test like ">50" or a range like "[50-60]".
It work for ">50" on expression evaluator but I don't suceed with the range.
Do you have an idea?
Thanks!
Forum|alt.badge.img+54
  • Nov 17, 2019 8:51 PM UTC
The range attribute needs to be structured like
(50,60) or [50,60]
to work with the In range operator.
Square brackets indicate can be equal to as well as greater than/less than
alc33
  • Nov 18, 2019 9:01 AM UTC
thanks for your answer,
I tried on expression evaluator but the result is <null>.
On my screenshot, @Value(test) = [50,60].
  • Nov 18, 2019 9:02 AM UTC
I missed that you were trying to do this in an Expression Evaluator, you need a tester
alc33
  • Nov 19, 2019 3:57 PM UTC
the problem is the test can be a range or a mathematical test (>50 for example).
so I would like to put the complete test on the 2nd attribute. ex :
attribute 1 : value to test
attribute 2 : test : ">50" , "in range [50,60]", etc.
so I would like to write on the Expression Evaluator : "@Value(attribute 1)@Value(attribute 2)". but it work only with the mathematical test...
so I can't use testfilter...
  • Nov 19, 2019 4:14 PM UTC
In Range isn't a math operator that you can use in the expressionevaluator
alc33
  • Nov 20, 2019 12:53 PM UTC
That explain why I don't succeed :)
So I get round the problem. With a tester I separate the value with a range from the others. If I have a range, I transform the brackets on < or > on the field and I use a specific syntax on expression evaluator.
Thanks!
  • Nov 20, 2019 1:09 PM UTC
Thanks!
I was going to suggest using a conditional statement in an attribute creator one step prior which could be used to create a correctly formatted statement
So create an expression depending on the value in test
