Test a value
  • Dec 13, 2021 7:46 AM UTC
  • 8 replies
  • 119 views
Hello there,
So I have two attributes: "Floor" and "Purpose".
Floor Purpose
1 Lobby
2 Restaurant
3 Swimming pool
So I want to verify the dataset. If the "Floor" is 1, "Purpose" must be lobby. May I ask what kind of transformer I should use?
Thank you very much.
Best answer by ebygomm
I'd probably use an AttributeValueMapper followed by a tester to save having to write a complicated conditional in the tester, especially if you have an external data source with the allowed values which can be imported into the AttributeValueMapper
So use the AttributeValueMapper to map the floor value to a new attribute called TestPurpose or similar, followed by a tester to check that TestPurpose = Purpose
nielsgerrits
Forum|alt.badge.img+67
You can use a Tester to do this. One of the most used transformers.
Floor != 1 OR ( Floor = 1 AND Purpose = Lobby )
TesterParameters
Forum|alt.badge.img+54
  • Dec 13, 2021 9:27 AM UTC
Forum|alt.badge.img+63
TesterParameters
I actually prefer the TestFilter over the Tester for the following reasons:
  • It allows you to perform multiple tests in a single transformer, rather than chaining mulitlple Testers in a row
  • It allows you to rename the output ports, which is a good idea with regards to Best Practices.
Thank you all for your help. Now my data it seems a little bit more complicated than I thought.
I have 3 data sets.
1) Floor (2 attribute = Floor & FloorID)
Floor = 1, 2, 3, 4, 5 ....
FloorID= a series of number
2) Units (2 attributes = FloorID & Carpark type)
FloorID = a series of number
Carpark type = 15-01, 15-02, 15-03, 16-01, 16-02, 17-01, 17-02 ....
3) Excel (Carpark group)
Carpark type: 15-01, 15-02, 15-03, 16-01, 16-02
Here is what I need to do.
1) Extract "Floor" data that are floor "5", with all the FloorID
2) Use the selected FloorID to find all the units that matched.
3) Compare selected data (Step 2) with the excel to check if it is in the range.
Thank you in advance.
Have a good day.
I have 3 data sets.
Have a good day.
First a TestFilter or Tester to select floor 5, then a FeatureMerger to join that to the Units. Then the Merged output from that into another FeatureMerger to join it to the Excel and see what's merged/unused.
So I still have a minor problem. I am able to merge the floor and unit.
Lets say
Floor Type (Unit)
1/F 1-01, 15-01, 15-02 ...
2/F 1-01 , 2-01 ...
On each floor, I am able to find all the types (Unit) and store those in the "list". If there are one type (unit) is matched with the excel list on each floor. Then it is ok. My final goal is to find out which floor that the types (unit) are not on the excel.
This image shows what I got so far. Do I need to use "ListExploder" to explode the list first?
Thank you
sample
Yes, you'll need to explode that list to separate features if you want to use it in a FeatureMerger
Got it, thank you very much! Merry christmas and happy new year! :)
